2006-02-07 11:23 AM
2006-02-07 11:44 AM
2006-02-07 01:12 PM
fuzzytnth3 wrote:The key trick here is to use the +256 modifier to the base hotspot. This is the easy (only?) way to get both ends of the value to stretch.
I've just tried adding some HOTSPOT2 commands to the four external corners of the object and that has got the height to work but it hasn't worked for the width
I'll keep bashing away till I get the pesky thing to work!!
2006-02-07 01:25 PM
2006-02-08 02:39 AM
2006-02-08 01:22 PM
F. wrote:No it is not necessary to use the A,B parameter to control the size of your object.You can make your own parameter and leave A,B unused
Can you post your master script? I think, there is something wrong with your parameters-command.
The size in the preview window is the real size of the object, if it differs from the nominal axb-size. Seems your parameters-comand does not work.
2006-02-08 02:46 PM
No it is not necessary to use the A,B parameter to control the size of your object.You can make your own parameter and leave A,B unusedThat's right, but he wants to select the object by a certain size. For this he wants to set the size depending of the selected table. I suggested, that the used PARAMETERS-command does not work proper.
2006-02-08 10:46 PM
2006-02-09 03:14 PM
