Fit wood wall stud
Hi! everybody asking for help.
How can I fit wood wall stud to composite wall core?
(Refer to Image)
2 Replies 2
One way is by slightly modifying the wall accessory script as described by Mick in this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=37903
Some additional, general info about the framing accessory is here:
http://www.archicadwiki.com/WallAccessories
Thanks for answer Karl Ottenstein!
I have solved your posting and few modify
First you must place the object in plan.Then select the object and hit 'ctrl+Shift+O'(option+command+o=mac). This opens the object. A dialogue box will then open and you will see on the left the parameters tab is automatically opened. Now select "new" in the top tab. This creates a new parametric function at the bottom of the list. In this new function – under the Variable column put "F" and in the Name put "Finish Thickness".
Make sure the type is on “length” and add 13(0’-1/2”=US Dimension) into the Value (default value – I have set to 13mm Plasterboard or Drywall for my American friends!)
