Barbara Franco
Flexible Shelf
Hello everyone,
Trying to use the Flexible Shelf - Archicad 29. I want to customize, but when I'm in 3D it doesn't show any editable hotspot at the top of the row... Anyone already try? And worked? any tips?
Thank you!
1 Solution
The bottom layer is not adjustable with hotspots as it doesn't need to be.
That is simply dependent on the length of the object itself.
Barry
Go to post
4 Replies 4
I can see them.
Barbara Franco
Thank you Barry, maybe I'm doing something wrong here... but for me it will only start to elevate the object.
I'm starting with only one layer because I want to go from the left side to right, to go 3 -2 -1 box like a stair, but I can't do that.
Are you able?
Thank you!
Barbara Franco
Got it!!! I start with 2 rows and reduced the last box.
Thank you anyway for previous answer!
Barry
