Fragment2 command - pen separation
Hi there
Is there any chance to set different pens for contour, fill and background when using fragment2 command?
Doing it as shown below changes either pen:
PEN frag_cont
set fill frag_fill
FRAGMENT2 1, 1
2 REPLIES 2
Why not a plain good 2d script but the binary fragment?
Drag the 2d window content to 2d script...make subroutines & jumps
The life will be easier.
Best Regards,
Piotr
Thank you Piotr for your response.
Nevertheless I need plenty of fills in my 2D symbol, that is why I wanted to avoid such time-consuming actions like you mentioned - dragging, setting subroutines, and setting fill for every poly separately. That is why it would be much better for me if there was a chance to set those pens using fragment2 command.
