Llian
Window door opens
I have done this but there is just so much hidden treasures in AC20...can't hold my breath in the deep ocean.
Where can I find the setting to open the window? By default, the casement window leaf is closed on floor plan. I want them to be opened at angle.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 Replies 4
Should be in the plan, the magenta dot.
If not is in the "Opening Type and angle panel" in the window tool setting, anyway I'm using the INT version, so yours could be a little different.
Llian
THANKS...and found it in the Sash !!!!
Just a small thing: it is actually a diamond shaped hotspot. The diamond shape indicates that it is a dynamic hotspot.
thanks Lazlonagy for the clarification!
