2014-08-29 03:48 PM
2014-09-10 04:19 AM
2014-09-10 01:50 PM
2014-09-10 04:28 PM
2014-09-10 08:57 PM
2014-09-15 03:20 PM
2014-10-23 06:44 PM
2014-10-23 08:32 PM
2014-10-27 06:02 PM
2014-10-27 08:12 PM
2014-10-27 09:11 PM
Hmooslechner wrote:
Very interesting object!
It looks easy to use in Your videos.
Your polygone-path border around the object and also the inner openings seems to consist of a static number of points - or do i have the false impression?
If that is fact - You should have a look at the free polygone-path with the ability to raise and lower the number of points in the path.
http://archicad-talk.graphisoft.com/viewtopic.php?t=43721
it is a bit tricky to learn to use it - but the possibilities are awesome.
I just tried that one from sinceV6. It is very easy - when finding the place to implement your own code - to build impressive GDL-Parts on that path.
The other one from mariosmic has more abilities - implemented curves. Mayby You should take direct contact to them?
Really great work so far!
