‎2012-12-22 11:37 AM
‎2012-12-22 12:34 PM
‎2012-12-22 02:15 PM
‎2012-12-22 03:14 PM
‎2012-12-23 02:12 PM
‎2012-12-23 02:28 PM
‎2012-12-24 02:04 AM
‎2012-12-24 01:51 PM
Douglas wrote:The next step to controlling which parts are shown is to add code that uses the Model View Options to turn on/off the various parts. You can see examples of this in the ArchiCAD Library such as for the Show Minimal Space of Furnishings and the Door and Window options. The coding this takes more time, but the variations can be stored as named MVOs, so can be tied into Views so the user does not have to remember to go back to the library parts to change the options.
The idea is to specify a post with a tenon at each end which can be sized and offset as required. I've just modified the GDL so the post part can be made invisible. This allows me to show only, say the lower tenon on a ground beam to represent a mortice, or the upper tenon on an eve beam for the same reason.
The alternative is three layers : one for the post and one each for the tenons. Then switch these on as required to be able to dimension say the ground sill in plan.
My approach seems to make sense, However, I wonder if it might an example of ignorange leading to overkill?
Douglas wrote:I cannot reproduce this bug. I am using the professional version on an earlier version of OSX, your operating system was not around when AC13 came out, so maybe there are issues some there.
Hello David :
The problem has reoccurred. I doubt the behavior can be down to a corrupt file.
Here are two examples :
‎2012-12-26 01:14 PM
