‎2019-08-08 02:56 PM
‎2019-08-08 06:13 PM
‎2019-08-09 03:13 AM
Joachim wrote:Thanks for the reply Joachim!
If you devide 2 Numbers, you always get as result a real number.
And you can turn the real number back again into integer by using INT command.
It would be helpful if you post your script with the issue.
! PARAMETRIC KITCHEN CABINET
! copyright 2019 by Jarrod Phillips
! VARIABLES
width = A
depth = B
height = ZZYZX
! FRONT KICKBOARD
add 0, doorPanelThickness+0.002+toedepth, 0
building_material buildingMat1, bForePen1, bBackPen1
cwall_ mat1, mat2, mat3,
toeHeight, 0, width, width, 0, toeThickness,
15, 15, 15, 15,
0,
0
del 1
! REAR KICKBOARD
add 0, depth-toeThickness, 0
15, 15, 15, 15,
0,
0
del 1
! LEFT KICKBOARD
add toeThickness, doorPanelThickness+0.002+toeThickness+toeDepth, 0
rotz 90
toeHeight, 0, depth-(2*toeThickness+doorPanelThickness+0.002+toeDepth), depth-(2*toeThickness+doorPanelThickness+0.002+toeDepth), 0, toeThickness,
15, 15, 15, 15,
0,
0
del 2
! RIGHT KICKBOARD
add width, doorPanelThickness+0.002+toeThickness+toeDepth, 0
rotz 90
15, 15, 15, 15,
0,
0
del 2
! BOTTOM PANEL
add 0, doorPanelThickness+0.002, toeHeight
building_material buildingMat2, bForePen2, bBackPen2
cprism_ mat4, mat5, mat6,
5, bottomPanelThickness,
0, 0, 15,
width, 0, 15,
width, depth-(doorPanelThickness+0.002), 15,
0, depth-(doorPanelThickness+0.002), 15,
0, 0, 15
del 1
! DOOR PANEL
if doorOn then
add 0.002, 0, toeHeight+0.002
rotz 360-doorAngle
building_material buildingMat3, bForePen3, bBackPen3
cwall_ mat7, mat8, mat9,
height-(toeHeight+0.002), 0, width-0.004, width-0.004, 0, doorPanelThickness,
15, 15, 15, 15,
0,
0
del 2
endif
! REAR PANEL
add 0, depth-rearPanelThickness, toeHeight+bottomPanelThickness
cwall_ mat4, mat5, mat6,
height-(toeHeight+bottomPanelThickness), 0, width, width, 0, rearPanelThickness,
15, 15, 15, 15,
0,
0
del 1
! LEFT PANEL
add 0, doorPanelThickness+0.002, toeHeight+bottomPanelThickness
rotz 90
height-(toeHeight+bottomPanelThickness), 0, depth-(rearPanelThickness+doorPanelThickness+0.002), depth-(rearPanelThickness+doorPanelThickness+0.002), 0, -leftPanelThickness,
15, 15, 15, 15,
0,
0
del 2
! RIGHT PANEL
add width-rightPanelThickness, doorPanelThickness+0.002, toeHeight+bottomPanelThickness
rotz 90
height-(toeHeight+bottomPanelThickness), 0, depth-(rearPanelThickness+doorPanelThickness+0.002), depth-(rearPanelThickness+doorPanelThickness+0.002), 0, -rightPanelThickness,
15, 15, 15, 15,
0,
0
del 2
If braceHorizontal then
! FRONT HORIZONTAL BRACING MEMBER
add leftPanelThickness, doorPanelThickness+0.002, height-frontBraceThickness
building_material buildingMat4, bForePen4, bBackPen4
cprism_ mat10, mat11, mat12,
5, frontBraceThickness,
0, 0, 15,
width-(leftPanelThickness+rightPanelThickness), 0, 15,
width-(leftPanelThickness+rightPanelThickness), braceHeight, 15,
0, braceHeight, 15,
0, 0, 15
del 1
! REAR HORIZONTAL BRACING MEMBER
add leftPanelThickness, depth-(braceHeight+rearPanelThickness), height-rearBraceThickness
5, rearBraceThickness,
0, 0, 15,
0, braceHeight, 15,
0, 0, 15
del 1
else
! FRONT VERTICAL BRACING MEMBER
add leftPanelThickness, doorPanelThickness+0.002, height-braceHeight
cwall_ mat10, mat11, mat12,
braceHeight, 0, width-(leftPanelThickness+rightPanelThickness), width-(leftPanelThickness+rightPanelThickness), 0, frontBraceThickness,
15, 15, 15, 15,
0,
0
del 1
! REAR VERTICIAL BRACING MEMBER
add leftPanelThickness, depth-(rearPanelThickness+rearBraceThickness), height-braceHeight
braceHeight, 0, width-(leftPanelThickness+rightPanelThickness), width-(leftPanelThickness+rightPanelThickness), 0, rearBraceThickness,
15, 15, 15, 15,
0,
0
del 1
endif
! SHELF
if numShelf > 1 then
add leftPanelThickness+0.002, doorPanelThickness+0.004, toeHeight
for k= (height-toeHeight)/numShelf to (height-toeHeight)-(height-toeHeight)/numShelf step (height-toeHeight)/numShelf
addz k
building_material buildingMat5, bForePen5, bBackPen5
cprism_ mat13, mat14, mat15,
5, adjustShelfThickness,
0, 0, 15,
width-(leftPanelThickness+0.002+0.002+rightPanelThickness), 0, 15,
width-(leftPanelThickness+0.002+0.002+rightPanelThickness), depth-(doorPanelThickness+0.002+0.002+0.002+rearPanelThickness), 15,
0, depth-(doorPanelThickness+0.002+0.002+0.002+rearPanelThickness), 15,
0, 0, 15
del 1
next k
endif
‎2019-08-09 03:54 AM
k= (height-toeHeight)/numShelf to (height-toeHeight)-(height-toeHeight)/numShelf step (height-toeHeight)/numShelf for count = 1 to numShelf addz k .... shelf stuff next count DEL numShelf
‎2019-08-09 04:05 AM
Barry wrote:Hello Barry,
Just having a quick look at your code you might want to try this for the shelf.
‎2019-08-10 09:26 AM
! SHELF
for count = 1 to numShelf-1
addz k
0, 0, 15,
0, 0, 15
next count
DEL numShelf
endif
Thanks for you help!‎2019-08-12 03:57 AM
