【GDL】Make Door Panels Overlap
Emil Meijer
Graphisoft Alumni
Graphisoft Alumni
Hello again,
currently playing around with some Custom Doors to widen my knowledge about GDL, and ran into a problem I've yet manged to solve.
I made 2 different Door Leafs that both have a small part sticking out at the end (see attached file), and I'm currently trying to find a solution to make these two panels overlap (the current setting pulls either back when trying to extend the other).
Currently using the AC13J_GS_ドア Subtype (ドア = door. Working in a Japanese environment), but if you would know of any useful parameters to make it possible to overlap these numbers, please do share.
0 REPLIES 0
