2012-07-04 10:43 AM
2012-07-04 12:41 PM
2012-07-04 02:09 PM
rocorona wrote:I think the location points in the 2D Script would need to be converted to object parameters so they could be scheduled, then Saved As... a cvs or similar file format.
Not sure, anyway, how you can export the values to an external file.
2012-07-05 01:50 AM
2012-07-05 09:25 AM
2012-07-05 11:58 AM
2012-07-05 03:08 PM
!!! Master Script x = SYMB_POS_X + GLOB_WORLD_ORIGO_OFFSET_X y = SYMB_POS_Y + GLOB_WORLD_ORIGO_OFFSET_Y !!! Parameter Script parameters x = x, y = yDeclare x, y params in the Parameters tab.
2012-07-05 08:44 PM
ila2 wrote:If I remember right the objects always give x=0 and y=0 when scheduled or listed. Writing the coordinates from the floor plan to an external .txt file might
Finally with the help of Schedules and Lists you can to choose the parameters (eg: posX, posY) what you want to save to xls. (Its important that it has to be filled the Name of the parameters)
2012-07-05 10:02 PM
Juha wrote:Sorry, I did not test it, but I trust you, Juha. One more GDL grip. Grrr!
work.
2012-07-06 09:21 AM
