Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
GDL Parameters
Is there a way for the custom GDL parameters to show up in the Info Box in Archicad?
Thanks in advance.
2 REPLIES 2
TomWaltz
No, but it would be really cool!
Tom Waltz
David Maudlin
SCSCadMan:
As Tom said, no, but there are 2 ways that might help:
1. Use the ID box. This value can be used as one of the object's parameters, and it is in the Info Box.
2. Use editable Hotspots, which give the user a pop up parameter input for either length or angle parameter(s) associated with the hotspot.
Having the ability to add parameters to the Info Box, and/or having more options for the type of editable pop up parameters (materials, line type, etc) would be great.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
