GDL Parametric Scripting Problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2017-06-20
05:31 PM
ā2023-05-24
10:00 AM
Rubia Torres
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-21 08:29 AM
A = leaf width
B = leaf height
zzyzx = leaf thickness
So if you are looking at the panel in 3D window of the object:
x-axis is the width
y-axis is the height
z-axis is the thickness
Depending on how you scripted your door, you may need to rotate it in the 3D script.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-21 05:19 PM
After you script your own parametric door leaf, once you call it in the Door you basically have no access to modify any of the parameters, and the Door on the plan will mostly pass A, B and ZZYZX down to the leaf. Some Doors scripts may be written to pass more parameters down to the custom door leaf, like finish and material, I haven't had much success with that in older versions and haven't tried any new tricks since.
Your door leaf must rely mostly on those three to auto-adjust other proportions -- in other words, all the panels or glass/muntin spacing in the leaf depend mainly on A and B, and then some ZZYZX.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-22 09:25 AM
Then it will scale automatically with you door frame object.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-22 08:47 PM
We use an exact same custom door many times, so I thought I would GDL script it and put it in our library. I guess I could also put it in a project file to copy and paste out of too. We actually have two custom doors we use many times. I just want it to scale proportionally with the changes in sizes. Plus, the parametric abilities of the GDL will help when adjusting the horizontal parts of the door.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-22 08:56 PM
matjashka wrote:I just tried to test this and it seems that I can adjust any parametric parameters that I set up in the GDL script in addition to the A, B, and zzyzx dimensions.
Everything that Erwin said above, plus:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-22 09:05 PM
I just tried to test this and it seems that I can adjust any parametric parameters that I set up in the GDL script in addition to the A, B, and zzyzx dimensions....within the door leaf itself, but typically not from the door where that custom leaf has been placed.
Unless the door object is scripted to pass those parameters down to the CALLed custom leaf, like in the case of default libraries and predefined door leaves. That's why it's best to rely on A, B and ZZYZX and make the custom door leaf act in a smart way based on these three, as much as you can.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-22 09:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-06-26 11:35 AM
I typically use some actual variable parameters for the surfaces. As these don't get passed on to the custom leaf (sadly!!).
Any parameters to do with proportions of trims, panels etc I just put in the 3d script at the top so I can adjust them as needed from the script.
Below is a custom panel that works fine. You just need to set the object's subtype to custom door leaf for it to get recognized by doors from the library.
For this one I use two parameters for surfaces 'mat1' (glass) and 'mat2' (the leaf colour inside and outside).
Some of the listed parameters are old and no longer needed, as these panels have been kicking about in our library for many years over many versions of ArchiCAD and from when the Dutch version was using their own library parts. I just can't be bothered trimming it down.
addx a/2 c=zzyzx ddd=c a=a b=b !v=d !mat1=e !handtype=f !g=g !mat2=g tsz=0 roehor=2 roever=3 links=0.150 rechts=0.150 bov=0.150 ond=0.285 tus=0.180 mid=1.100 paneelrandbuiten=0.010 paneelrand=0.060 paneelrandraam=0.040 raamb=0.056 raambov=0.499 raamond=1.652 glaslat=0.030 material mat2 !! hoofdvorm prism_ 10, ddd, -a/2, 0, 15, a/2, 0, 15, a/2, b, 15, -a/2, b, 15, -a/2, 0, -1, !! gat in hoofdvorm -a/2+links, ond, 15, a/2-rechts, ond, 15, a/2-rechts, b-bov, 15, -a/2+links, b-bov, 15, -a/2+links, ond, -1 !! binnenste paneel prism_ 10, ddd, -a/2+links+paneelrand,ond+paneelrand, 15, a/2-(rechts+paneelrand),ond+paneelrand, 15, a/2-(rechts+paneelrand), b-bov-paneelrand, 15, -a/2+links+paneelrand, b-bov-paneelrand, 15, -a/2+links+paneelrand,ond+paneelrand, -1, !! gat in paneel -raamb/2-glaslat-paneelrandbuiten-paneelrandraam, raamond-glaslat-paneelrandbuiten-paneelrandraam, 15, raamb/2+glaslat+paneelrandbuiten+paneelrandraam, raamond-glaslat-paneelrandbuiten-paneelrandraam, 15, raamb/2+glaslat+paneelrandbuiten+paneelrandraam, b-raambov+glaslat+paneelrandbuiten+paneelrandraam, 15, -raamb/2-glaslat-paneelrandbuiten-paneelrandraam, b-raambov+glaslat+paneelrandbuiten+paneelrandraam, 15, -raamb/2-glaslat-paneelrandbuiten-paneelrandraam, raamond-glaslat-paneelrandbuiten-paneelrandraam, -1 !! rand raam prism_ 10, ddd, -raamb/2-glaslat-paneelrandbuiten, raamond-glaslat-paneelrandbuiten, 15, raamb/2+glaslat+paneelrandbuiten, raamond-glaslat-paneelrandbuiten, 15, raamb/2+glaslat+paneelrandbuiten, b-raambov+glaslat+paneelrandbuiten, 15, -raamb/2-glaslat-paneelrandbuiten, b-raambov+glaslat+paneelrandbuiten, 15, -raamb/2-glaslat-paneelrandbuiten, raamond-glaslat-paneelrandbuiten, -1, !! gat in paneel -raamb/2-paneelrandbuiten, raamond-paneelrandbuiten, 15, raamb/2+paneelrandbuiten, raamond-paneelrandbuiten, 15, raamb/2+paneelrandbuiten, b-raambov+paneelrandbuiten, 15, -raamb/2-paneelrandbuiten, b-raambov+paneelrandbuiten, 15, -raamb/2-paneelrandbuiten, raamond-paneelrandbuiten, -1 addz 0.0125 !! verdiepte rand paneel prism_ 10, ddd-0.025, -a/2+links+paneelrandbuiten, ond+paneelrandbuiten, 15, a/2-rechts-paneelrandbuiten, ond+paneelrandbuiten, 15, a/2-rechts-paneelrandbuiten, b-bov-paneelrandbuiten, 15, -a/2+links+paneelrandbuiten, b-bov-paneelrandbuiten, 15, -a/2+links+paneelrandbuiten, ond+paneelrandbuiten, -1, -a/2+links+paneelrand,ond+paneelrand, 15, a/2-(rechts+paneelrand),ond+paneelrand, 15, a/2-(rechts+paneelrand), b-bov-paneelrand, 15, -a/2+links+paneelrand, b-bov-paneelrand, 15, -a/2+links+paneelrand,ond+paneelrand, -1 !! raam material mat1 prism_ 5, ddd-0.025, -raamb/2, raamond, 15, raamb/2, raamond, 15, raamb/2, b-raambov, 15, -raamb/2, b-raambov, 15, -raamb/2, raamond, -1 material mat2 del 1 addz -0.005 !! buitenste rand paneel prism_ 10, ddd+0.01, -a/2+links, ond, 15, a/2-rechts, ond, 15, a/2-rechts, b-bov, 15, -a/2+links, b-bov, 15, -a/2+links, ond, -1, -a/2+links+paneelrandbuiten,ond+paneelrandbuiten, 15, a/2-(rechts+paneelrandbuiten),ond+paneelrandbuiten, 15, a/2-(rechts+paneelrandbuiten), b-bov-paneelrandbuiten, 15, -a/2+links+paneelrandbuiten, b-bov-paneelrandbuiten, 15, -a/2+links+paneelrandbuiten,ond+paneelrandbuiten, -1 !! brede rand raam prism_ 10, ddd+0.01, -raamb/2-glaslat-paneelrandbuiten-paneelrandraam, raamond-glaslat-paneelrandbuiten-paneelrandraam, 15, raamb/2+glaslat+paneelrandbuiten+paneelrandraam, raamond-glaslat-paneelrandbuiten-paneelrandraam, 15, raamb/2+glaslat+paneelrandbuiten+paneelrandraam, b-raambov+glaslat+paneelrandbuiten+paneelrandraam, 15, -raamb/2-glaslat-paneelrandbuiten-paneelrandraam, b-raambov+glaslat+paneelrandbuiten+paneelrandraam, 15, -raamb/2-glaslat-paneelrandbuiten-paneelrandraam, raamond-glaslat-paneelrandbuiten-paneelrandraam, -1, -raamb/2-glaslat-paneelrandbuiten, raamond-glaslat-paneelrandbuiten, 15, raamb/2+glaslat+paneelrandbuiten, raamond-glaslat-paneelrandbuiten, 15, raamb/2+glaslat+paneelrandbuiten, b-raambov+glaslat+paneelrandbuiten, 15, -raamb/2-glaslat-paneelrandbuiten, b-raambov+glaslat+paneelrandbuiten, 15, -raamb/2-glaslat-paneelrandbuiten, raamond-glaslat-paneelrandbuiten, -1 !! rand raam prism_ 10, ddd+0.01, -raamb/2-paneelrandbuiten, raamond-paneelrandbuiten, 15, raamb/2+paneelrandbuiten, raamond-paneelrandbuiten, 15, raamb/2+paneelrandbuiten, b-raambov+paneelrandbuiten, 15, -raamb/2-paneelrandbuiten, b-raambov+paneelrandbuiten, 15, -raamb/2-paneelrandbuiten, raamond-paneelrandbuiten, -1, -raamb/2, raamond, 15, raamb/2, raamond, 15, raamb/2, b-raambov, 15, -raamb/2, b-raambov, 15, -raamb/2, raamond, -1 del 1 !! neus addz ddd addx a/2 addy 0.01 roty -90 rotz 90 addz 0.017 prism_ 5, a-0.034, 0, 0, 15, 0.07, 0, 15, 0.07, -0.005, 15, 0.05, -0.02, 15, 0, -0.02, 15 del top end
www.leloup.nl
Windows 10 Pro
