GDL Picture2 - how to define file path
It's been a long time since I've done this, and seem to have to relearn it everytime I try...
How do I define the file path to an image I want to call in a Picture2 command?
I thought using the filename by itself, with no directory structure, would prompt AC to look in the ArchiCAD Data Files folder. Doesn't seem to be working.
We're working on OSX.
Thanks.
1 Reply 1
Aussie John
Called elements need to be located within the loaded library. If the file name has spaces put inverted commas each side otherwise just call the element.
The extension is not required
Cheers John
[/size]
