Location of subtype gdl files
Hello everyone,
i'd like to take a look in the gdl files that define the object subtypes to understand their built in functionalities.
The subtype hierachy shows the path as:
/ARCHICAD 21/Support/ARCHICADRessources.framework/rfs/filename.gsm
The only problem is that there is no folder called "rfs" in the .framework file. Can anyone explain where i could find these files and maybe how ArchiCAD is working with .framework files?
Thanks in advance!
Lingwisyer
Guru
You can open them by going through the calls in an object. Highlight the name after the call, then select "Open object". Do not know of a way to open them directly...
Ling.
Or use "open by subtype" command (located in GDL editing toolbox)
Piotr
