GDL Question
Vitruvius
I've just upgraded to AC 9 and have a door symbol I've been using for years without problem - in fact it still works just fine. But, when I open it to edit the GDL code and ask AC to "check script" I get the following error message:
' USE OF REAL TYPES CAN RESULT IN PRECISION PROBLEMS........ '
Which highlights the following code
IF WIDO_ORIG_DIST <> 0 THEN LET WindowRadius = etc., etc.
IF WIDO_ORIG_DIST = 0 THEN LET WindowRadius = 0
Any thoughts on this?
Cheers, Cameron
iMac G5 20" / AC 9
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
Search "use of real types" and you'll find a thread that discusses this at length.
One of the forum moderators
Vitruvius
Many thanks for the tip, Karl!
Problem 'solved' with an INT(WIDO_ORIG_DIST) = 0
Probably not elegant and rife with error. And probably not the correct solution. Epsilon is Greek for SNAFU. But there ya go.
Man, is this an arcane sport or what?
Cameron
iMac G5 20"/AC 9/& perpetually flummoxed when I think I've finally figured things out...
PS - I now know why Dwight looks like a Tai Chi maestro - he's not; he's on a sinking ship urgently trying to flag down some help...
