GDL VOLUME3D() Command
I have searched thru the GDL Reference guide, and the only example I can find for the use of the VOLUME3D ( ) command is just that.
VOLUME3D ( )
I have a cylinder (scripted in the 3D Script), how do I get the volume of that cylinder to show up (correctly) in the Parameters of the object? If someone would be kind enough to give me an example of how I would do this it would be much appreciated.
Thanks ahead of time...
1 Reply 1
Ben Cohen
AFAIK VOLUME3D() is for the property script only. So you have to run a list to get the volume : you cannot drive the value into a parameters
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
