2006-05-18
08:15 PM
2023-05-24
10:33 AM
Rubia Torres
2006-05-18 08:58 PM
Mryan wrote:The RCP option works by completely removing the object and only showing the opening. It's really not even GDL-related.
Ok I have an object that in plan is supposed to represent one thing on one plot sheet and something else on another. Is their a way to for the object to automatically take settings based on the Model View Option?
Example – if you draw a wall with a door and then go to the model view option and then go to RCP-empty... the door swing is gone.
2006-05-18 11:31 PM
2006-05-19 02:51 PM
Dan wrote:Little confused ... I'm not sure exactly how this works
Yeah, sort of...basically you have to script the objects to be aware of the status of the "Doors & Windows:" display options.
Following is a snipet of a master script I use to turn on and off special 2d text display on my windows:
xyz=Request ("window_door_show_dim", " ", show)
if show = 0 then
state=0
else
state=1
endif
So basically when state =1 then you can script whatever behavior you wish when that display option is active.
HTH,
Dan K
2006-05-19 03:20 PM
Dan wrote:That command is a pretty limited use, though, since it only works if the Show Doors/Windows is get to "Show with Dimension." The other settings cannot be individually identified to only use the RCP option.
HTH,
Dan K
