GDL coding for composite name
Could anyone tell me the coding for the name of a composite? Like GLOB_ID is the coding for the global id.
Thanks,
Michele
4 Replies 4
WALL_COMPS_NAME
I hate when this happens. I look for the answer, I can't find it so I email you guys, then I find the answer.
Thabks again,
Michele
Michele;
I have copied the text below from the AC (9) help guide (GDL Reference Guide > Miscellaneous > Global Variables > Wall parameters - available for Doors/Windows) - although I have never used this variable.
You could extract the information using vardim2 (to determine the number of layers in the composite).
HTH - Stuart
WALL_SKINS_PARAMS - parameters of the composite wall skins
array with 12 columns: fill, thickness, (old contour pen), pen of fill, pen of fill background, core status, upper line pen, lower line pen, upper line type, lower line type, end face pen, fill orientation and up to 8 rows, core status: 0 - not part, 1 - part, 3 - last skin of core, fill orientation: 0 - global, 1 - local
Uh oh - ok. Misunderstood anyway
Michele wrote:
WALL_COMPS_NAME
Thabks again,
Michele
This link has more info on this:
http://www.graphisoft.com/support/archicad/archiguide/generalparameters.html
also:
SLAB_COMPS_NAME and ROOF_COMPS_NAME for slabs and roofs.
