‎2009-07-01 10:32 AM
‎2009-07-02 06:33 AM
‎2009-07-03 09:19 AM
‎2009-07-06 11:23 AM
‎2009-07-06 12:30 PM
"NandoMogollon" wrote:
!!!!-------->>>>>>>>>>>>>-------------- REPLACE THE TEXT BELOW --------<<<<<<<<<<<<<-------!!!!!
"Material,"
"Size: Width x Height x Deep or Thickness, "
"Element Type or Name, "
"Purposes, "
"Located at..."
"Color and Finishes definition, "
"Provider and reference, "
"Installation or Construction notes."
!!!!-------->>>>>>>>>>>>>-------------- REPLACE THE TEXT ABOVE --------<<<<<<<<<<<<<-------!!!!!
!!!!-------->>>>>>>>>>>>>------- AND SAVE AS, WITH A DIFFERENT NAME --------<<<<<<<<<<<<<-------!!!!!
Ideally, I would like to get back to the original idea of having a single object, and LINK each of the Texts above as Variables on an external file, like an excel file or a TXT file.
With the GDL TEXT I/O ADD-ON it may be possible, but is out of my area of knowledge.
In that case I would need to select the Spec wanted from a pop up menu on the settings of the label, not by choosing a different Label, but that's another story.
I'm a bit busy by now, and probably I won't have time to keep developing this object. Feel free to do it. Just let me know if any of you can find a way to do the "Linking Trick".
Best Regards
Nando
