ā2011-07-20 06:42 PM
ā2011-07-20 08:19 PM
PROJECT2 3, 270, 2This will tell ArchiCAD to look at the object from above and draw what it sees in 2D. Of course there are issues with this approach. If you use this frequently, or use parts that use this technique frequently, you will slow down the program. Also you may want a more symbolic view of the object in 2D than this provides. To handle these cases, you need to script the 2D yourself.
ā2011-07-21 01:05 AM
ā2011-07-21 03:01 PM
omar wrote:The PROJECT2 will not do this, you will need to start to learn GDL scripting to accomplish this (and many other features). While saving objects from a .pln file (the 3D Script looks like this) can create simple (basically non-parametrtic) objects, the power lies in scripting.
Is there a way i can use fill on the object, so that i can select it without trying to find the nobes in the corner of the object?
ā2011-07-22 03:54 AM
ā2011-07-22 07:28 AM
ā2011-07-22 08:43 AM
