GDL subtrat help
I use proflier to build that blue curve wall, and make slab GDL file to insert into the project. I tried to use that GDL to cut a hold on profiler wall. The problem is after I use "Edit Targets & object" to subtrat the proflier will disappear. Do I make any mistakes? What should I do to make that proflier cut a curve hole?
4 REPLIES 4
use 'profiler' to create BOTH the wall and the subtracting element
create both elements using a FILL, not lines
should work
bill
Thank you! I don't know why I make my work harder. It works. and it's much faster.
Bill,
Could you explain why Ashley's method fails
and why your method works.
I would be very interested to know.
Thank you,
Peter Devlin
boolean operations don't like (zero thickness) surfaces. and gdl objects are often flakey in booleans, at best
bill
