GMS Script Error
When opening a file I get the Error:
"Unknown extension
at line 798 in the 2D script of file CavityClosure.gsm."
And every time I change the view the error returns. I've looked for the CavityClosure object file, but have had no luck so far. Any suggestions on how to fix the corrupt file?
Version: ArchiCAD 11
OS: Windows XP
There appears to be 13 more warnings upon closing. I believe the whole library is corrupt. I am updating and patching. Hopefully this works.
After a little tinkering. I got it to work.
Glad you got it working again. It's just a thought if it shows up in the future, but have you checked the settings of the cavity closure within the doors and windows you have used in the project? You might have an incorrect setting, maybe referring to a missing fill or linetype, or even an impossible dimension perhaps.
Hope that helps.
Thanks for the suggestion. The problem is back again. (And gone again.) I'll check it out.
