2014-10-07 06:31 PM - last edited on 2023-05-24 12:32 PM by Rubia Torres
2014-10-07 09:03 PM
2014-10-07 10:34 PM
2014-10-09 02:52 AM
2014-10-09 03:05 PM
2014-10-10 05:10 PM
2014-10-14 11:59 AM
2014-10-14 05:14 PM
laszlonagy wrote:You're right, when I create a new object in AC18, I can make a CALL to the "Simple door opening" macro without problem although I use the same syntax as my "old" object.
This might have something to do with the fact you bring GDL objects created in previous versions into ArchiCAD 18.
laszlonagy wrote:What should I do to migrate my object to AC18 ? I had no problem before to upgrade from 9 to 12 and from 12 to 16 ...
I wonder if this could be a migration problem?
2014-10-14 06:55 PM
2014-10-15 10:26 AM
laszlonagy wrote:Done. Thanks for your support.
report this to your local reseller
