Link
GSM Properties
This may be obvious to some users, and while I don't claim to be a GDL guy, I just found it out. On a PC, if you right click on a library part and select 'Properties', you can find out many things about the part, including the scripts and preview info.
Check out the attachment. The same thing probably exists on a mac's 'Get Info' dialog.
If you already knew this - I'd believe you!!
Link.
10 Replies 10
~/archiben wrote:
let's see just what proportion of mac users there are out there using archiCAD.
I just did a quick tally of my own clients and found that about twice as many use Macs as use PCs. While I realize this is not a statistically representative sample, I have never favored one platform over another (as far as choosing clients goes) and I have seen no bias in referrals. Every local estimate (Germany, France, dealers, other consultants) I have heard is that ArchiCAD users are about 50% Mac & 50% PC.
It would be interesting to run a tally of from the user profiles to see how it breaks out among us ArchiCAD talkers. (Djordje, is this something you can easily do?)
I strongly suspect that there are far more Mac users than Graphisoft thinks there are (from what I understand they just GUESS that the ratio is about 85% Windows & 15% Mac). It seems that this is market survey info that they should really KNOW. (Apologies to GS if they do have hard data on this.)
