GSM files parameters export issue
Hello everyone,
I've been struggling with parameters of models exported to GSM from IFC. I'll try to describe this issue. When I add parameter cost, everything seems be ok. I do it as atl+cmd+o, then add parameter, then I save item at other localisation than embedded library, because I make it for our team. When I want to put this item in the same AC file where it has been done, everything is ok.
When I try to put it in another AC solo file, by import to embedded library item disappears. On floor plan I see only point. When I check this item point by cmd+T, I see description of item with sizes, but nothing more.
Does anyone know how to save items to keep parameters?
Thank You
K.
4 Replies 4
Alex Moruzzi
Did you try placing the object by choosing the library (folder of the object) and not importing the object ?
Hi Alex, Thank You for respond. Yes I did. Still not working. All parameters given to object has gone...
Maybe I do something wrong...
Let me explain way how do I do it.
Merge IFC file->unlock layer+convert to morph->libraries and objects->save as...->object -> load other object->place the object->alt+cmd+o->add parameters: gs_list+gs_cost->save as...->done
Then in new AC solo project:
Object->load other objects->place object->placed object does not come up, there is point only->cmd+T->no 2d or 3D view no parameters....
Thank You
K.
Solution found. I did updates. Now everything works. Thank You
