Garage Roller Door
Does anyone have a solution for a standard garage roller door in ArchiCAD 20?
See attached image.
4 Replies 4
Do you have the Australian Essentials library?
If so there is a roller door in there - although not as detailed as your image.
Thanks Barry,
I was using the Aus Essentials Library 19, which didn't seem to have the roller door. Just downloading the up to date version now.
Bryn
Thanks Barry,
Bryn
It should be in the 19 AUS ESS library as well.
