Gdl script
Is there a way to lock text in the scrip?
I Would like to lock "made by my_name"
4 REPLIES 4
Not in the context you are looking for. You can only lock parameters.
LOCK "made by my_name"
But if someone has access to the script it is easily undone.
There is supposed to be a way to hide scripts using xml maybe someone who is more knowledgeable about it can post.
Thank you Jeffery.
Can i hide the script? If so, do you know how?
There is a tool that can export the gdl scripts to xml in 15 you can find it in "PreviousLP_XMLConverter" subfolder in Your AC instalation directory.
The tool can export gdl to xml and vice versa and while doing the xml to gsm conversion you can modify the xml files so that the scripts will be hidden.
You can find the manual in the documentation subfolder.
Best Regards,
Piotr
Thank you Mr Dobrowolski.
This looks kind of complicated. I do not know were to begin. how does it work? and what should i do ?
i am sorry for my "rookienes":)
