Get direction window is facing
In a window schedule, can I get the direction a window is facing. I know the information is in there somewhere but I can't see anywhere to extract the data. I know I can insert the direction manually into the schedule but it would be nice to do it automatically. I need the window direction for a energy modeling program I use.
Kris
5 Replies 5
No one has a clever idea?
Kris
Erwin Edel
As in South, North etc?
I don't think the window 'knows' this.
The Energy Evaluation addon might have this data, but the GDL object for the window itself does not have a parameter for this.
So yes, you'd have to manually set it for your windows (for example with a property) and schedule that.
At least, as far as I know.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I saw a schedule from the Bim Bakery add on that included the compass direction which led me to believe that AC somehow knows the window direction. I will look at the Energy Evaluation add on. Thanks.
Kris
DGSketcher
Legend
I add a tag to my window IDs manually with NSEW. In theory it shouldn't be that difficult to determine within AC and as already said the EE can work it out so why can't it be a parameter in schedules?
Perhaps the new parameter evaluation in 22 will make it possible?
There is a wish for it floating around somewhere if you want to add your name.
Erwin Edel
GDL does have a way to know the North set up in project. Probably with some clever scripting you could determine direction for windows, but in the standard library objects this is not being done at the moment. So you would end up with custom objects.
www.leloup.nl
