‎2008-12-10
10:37 PM
‎2023-05-24
11:58 AM
Rubia Torres
‎2009-11-11 04:41 AM
lec1212 wrote:It will be a mystery even to those on RSS (I hope
Well Barry since I don't have RSS feed,(or knew about it),
I'm going to assume you wrote "darn",
right?
lec
‎2009-11-11 04:50 AM
‎2009-11-11 12:55 PM
Steven wrote:Did you have a quick look through the manual? This object has a number of unique characteristics, so it's worth having an overview of how it works. I've attached an example that might reflect what you're trying to do:
I got the MJO and was spitting excitement to try it out. Then, I opened the window preference box and couldn't figure it out, it all looks greek to me (sorry to anyone from Greece...).
I just want a <b>[censored]</b> double hung mulled window!!!
‎2009-11-11 02:12 PM
‎2009-12-21 03:01 PM
‎2009-12-21 03:45 PM
Frank wrote:Every frame in a given unit can have a unique configuration, so every window can be set to open left/right/top/bottom or to be fixed.
However, I miss an option e.g. to do a simpel window where there is one fixed frame and one open frame
‎2009-12-22 11:14 PM
‎2009-12-22 11:40 PM
ksymons19 wrote:ArchiCAD automatically handles the units in GDL objects, so they transparently show metric or imperial units depending on your settings. This means the object will work with any units. The default settings could possibly be improved for imperial usage, but I don't think this is a significant issue.
I wanted to know if the parameters have the ability to respond to feet/inches input? Or is it all still metric?
‎2010-06-19 12:22 PM
Ralph wrote:Is there a way to define trapezoid form panes in the modular joinery object?ksymons19 wrote:ArchiCAD automatically handles the units in GDL objects, so they transparently show metric or imperial units depending on your settings. This means the object will work with any units. The default settings could possibly be improved for imperial usage, but I don't think this is a significant issue.
‎2010-06-19 09:22 PM
Rose-Marie wrote:Sorry, not at this stage. It's something that can be added, but it comes down to the feedback received through resellers/distributors. If there are many requests for this feature, there will be impetus for the Modular Joinery to be extended.
