2008-12-10
10:37 PM
2023-05-24
11:58 AM
Rubia Torres
2012-09-20 01:49 AM
2012-09-20 09:39 AM
2012-09-20 11:21 PM
Achille wrote:There are 2 places that materials can be set (referring to the attached image):
I downloaded the modular joinery object.
I cannot change the materials of the frame from the ones that come standard...
2012-09-21 03:04 AM
Ralph wrote:Achille wrote:There are 2 places that materials can be set (referring to the attached image):
- 1. In the
I did not end up with it, maybe it's not there or I just missed it.2D/3D Appearancepanel. Click on the 3D tab and select the global materials. These materials will be applied across the whole object.
2. In theDetailed Specificationpanel, you can override the global materials if the selected frame is different. Just check the box under the frame menu and pick the required material. Has the manual for this object been made available through BIMcomponents too?
The last manual for MJO that I have is for 14.
2012-09-21 03:24 AM
2012-09-21 10:32 AM
lec1212 wrote:I just tried it now (with 3270) and it was still available. However, the object is still missing some images for the user interface. Hopefully GS will sort that out soon.
And when I tried to download it again from within AC16 with new build 3270, MJO is not there, so could not see if manual was something I missed last time I did download MJO from within AC-16.
Bug?
2012-09-21 12:47 PM
- 1. In the
Thanks, Ralph.2D/3D Appearancepanel. Click on the 3D tab and select the global materials. These materials will be applied across the whole object.
Well, I tried to change the materials from the 2D/3D Appearance panel. And there is no way to change the frame material. It always stays as aluminium and wood.
Note: This happens in the Modular Door. Yesterday when I searched for the Modular Window it wasn't available on the BIM components portal. Today it was, so I downloaded the Modular Window, which works OK on the materials.
I think there is some bug with the materials on the Modular Door Because you can change the material on the single frame, but the material seems to be on the outside instead of the inside.
Also, in your screenshot I read "frame" and "mulion" whereas I see "sash" and "rail". How is that?
2012-09-21 02:08 PM
Ralph wrote:Well this morning MJO was available in default.tpl of build 3270 so that's a good thing.lec1212 wrote:I just tried it now (with 3270) and it was still available. However, the object is still missing some images for the user interface. Hopefully GS will sort that out soon.
Bug?
While the manual is unavailable elsewhere, you can download it here. It hasn't been revised from the earlier version, but the new additions are based on all the same concepts.
2012-09-21 02:24 PM
Achille wrote:I'm trying to reply, but ArchiCAD-Talk is currently falling over with:
2012-09-25 02:09 PM
Achille wrote:I checked the original the objects and they seemed to be working fine. I can't check what's happened with the versions on BIMcomponent because GS has password-locked them (but didn't communicate with me). Some of the UI images are also missing on BIMcomponent, so you may not always see the same thing as the attached images. There are up to 3 places you can change the materials, but in most cases the first is sufficient:
