HELP!!! GDL calculations based off of a slab
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-08-20 05:45 PM
2008-08-20
05:45 PM
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-08-20 07:09 PM
2008-08-20
07:09 PM
The SLAB_TOP_SURF global is available to a label part and gives you the top surface area.
It is also trivial to get slab areas in the interactive scheduler.
Getting the X and Y extents of an arbitrary polygon is a bit more of a chore.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-08-20 07:22 PM
2008-08-20
07:22 PM
The current calc is using SLAB_TOP_SURF to calculate the footage of board needed. We have changed our specifications for installing the deck boards from running horizontal and only using 1 length to running diagonal and using 3 different lengths depending on how deep the deck is. So I was hoping to be able to find a way to distinguish the slab size in x and y to determine which length of board to calculate (without using multiple links or composite names). I figured it was a long shot but I thought I would ask. Thanks for you help I am going to have to go back to the drawing board.
Thanks Dereck
Thanks Dereck
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-08-20 07:41 PM
2008-08-20
07:41 PM
You could model the planks to their nominal dimensions and use SEOs as a circular saw to trim them to fit 😉
This is not really as crazy as it sounds since you can use the original deck slab as the operator and use the intersection function in the SEO.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-08-20 08:01 PM
2008-08-20
08:01 PM
I need something a lil simpler, I work for a log home manufacture and I am trying to keep things as simple as possible, we do to many drawings with to few ppl. I love the Idea though and can think of quite a few times to use it on other jobs and some of our modeling projects. Thanks for the Idea
Dereck
Dereck
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-08-20 08:06 PM
2008-08-20
08:06 PM
There may be a way. If I think of something I'll let you know. I'm sure it could be done as a slab accessory but that would be, as the programmers say, non-trivial.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-08-20 08:10 PM
2008-08-20
08:10 PM
programming is never trivial! the more I get into it the more I realize I don't know, but I am learning fast. Thanks for your help! If anyone else has an Idea please post it.
thanks Dereck
thanks Dereck
