Hatch defaults to library parts
All library parts in A10 default to a hatch fill every time it is opened, does anyone know how to change the default?
Hi Rboo
I think this has been discussed before (you could try a "search", button above).
Suggested fixes include opening the library parts, modifying them as necessary and saving (a copy), or setting up favourites of commonly used parts with all settings correct in a template file.
Djordje
The default fill is either wrong, or you have opened a file that set the default fill to a wrong one. Are you continuing a file that was created in a previous version?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
