2021-06-15 06:42 PM - last edited on 2023-05-25 05:00 PM by Rubia Torres
Solved! Go to Solution.
2021-06-17 06:40 PM
Braza wrote:It really does the job but it is kind of a cheating with wall settings rather than correct solution, but as workaround it is quite nice, thank you for that.
I managed to combine Reveal (With the last option) and Wall Closure (with Plaster Reveal Option).
In the Reveal Setting you can control both sides respective skins.
Just checked the 2d and its ok.
Hope this helps
2021-06-17 07:55 PM
Jan wrote:I am glad it helped.
2021-06-18 06:40 AM
2021-06-18 08:03 AM
Jan wrote:
My goal is to understand why archicad shows menu "turn plaster" frozen for hinged doors while for user Lingwisyer it's not frozen as you can see above.
2021-06-18 08:24 AM
Barry wrote:Hello ! I have no problem to access my file not big drawing anyway, so I will upload a sample wall new scene that has that frozen menu, pln file in rar archive. archicad is 24 6001 international version.
It is really hard to say without having the file.
Maybe the library language version (i.e. USA is slightly different to INT) - what language version are you using?
Could be some other setting in the door that is blocking those settings.
Maybe it is the wall composite type (just a hunch).
Rather than us having access to the whole file, select the wall and door in plan and then save the selection as a module file.
Than attach the MOD file here (you may need to zip it as MOD files are not allowed as attachments) or share it via a cloud share.
2021-06-18 09:57 AM
2021-06-18 11:08 AM
2021-06-18 11:26 AM
Barry wrote:Sure, uploading here tells me "file too large" but it is only 5.5 megs, I will post a link from filehost
Are you able to please ZIP the files?
I have nothing that can open a RAR file.
2021-06-18 11:46 AM
Jan wrote:This is because you probably have your casings on.
2021-06-18 12:05 PM
Braza wrote:Well that was it ! Thank you so much Braza! I didn't turn them on and if they are turned on by default why I don't see them on plan ? how to make them visible like on image below?
