Learn more
Hinged gate 12
Anyone else noticed that the hinged gate 12 looks fine in plan, but in 3D the gate is laying on the floor?
4 Replies 4
Rakela Raul
ac12 latest hotfix, win, looks ok here
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Oddly enough - you're both right!
The Hinged Gate object for some reason can be inserted both as an object (object tool) and as a door.
When inserted with the Door tool, it shows properly in 3D.
When inserted with the Object tool, it shows flat on the ground in 3D.
Given that the subtype is 'Model Element', I don't have a quick answer to why this library part shows up as available with both tools...
Thomas Holm
You might need a gate to the underworld...
Thanks for the simple explanation Karl.... Guess I should have thought of that one!
