‎2007-02-27 02:36 AM
‎2007-02-27 03:19 AM
Aussie wrote:I'm no guru, John, but is this what you want?
for any given roof of pitch "roof_ang" what is the formula for calculating the angle of an element placed oblique the fall line of the roof ("obj_ang")
eg at the hip - "obj_ang" would be 45. (if roof pitches are equal)
‎2007-02-27 08:39 AM
Rod wrote:Rod- Ill have a closer look at your library part. What i am hoping to do is be able to place a capping as a roof accessory and by varying the 2d angle in plan get an automatic correction the the inclined angle.
If so the maths is in the part here.
‎2007-02-28 06:31 PM
Aussie wrote:I don't know if it helps but I find it much quicker to cut a section through and measure the angle rather than getting into maths. Let the computer do the maths - that's what it's for!
heres a q for the maths gurus.
thanks
‎2007-02-28 10:51 PM
‎2007-03-01 01:27 PM
‎2007-03-01 04:53 PM
gpowless wrote:Thats not correct, its 17 not 18. For example, a 4"/12" roof pitch has a 4"/17" hip/valley pitch.
In terms of carpentry, the hip slope is always (pitch)/18 when the main pitch is expressed in (pitch)/12.
