Mats_Knutsson
Mentor
How can I model a small bent spiral (attach)?
I converted a sketchup object but need to modify the spiral and thought I 'd better do the spiral myself but I got stuck. How would you model this? It does't have to be perfect.
Br,
Mats
AC 25 SWE Full
3 Replies 3
Podolsky
Ace
There is spiral object in ArchiCAD library under Basic Shapes section. But it's not bending. Maybe someone worldwide has created bended spiral object - but I didn't see.
Maybe you need to model it in more advanced modeller. Try Blender. I assume it would be faster to do it in external animation program than trying to figure out how to do it in ArchiCAD. I, with my 20+ years experience, don't know anything apart having it programmed on GDL, that in case of bended spiral is not straight forward. I will need at least several days to figure out how to describe mathematically bended spiral path to program the object.
Mats_Knutsson
Mentor
Yes probably the way in Blender. GDL math is for Yoda.
AC 25 SWE Full
David O
Hi Mats
Did you manage to get your spiral made? If not let me know the sizes & I will make for you
Regards
David
