How do I adjust how deep a window sill projection is?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2020-09-28
04:19 PM
ā2023-05-24
12:24 PM
Rubia Torres
Thanks!
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-09-28 05:38 PM
If so, select your window > Basic Window Settings > Fixtures and Fittings > Sill
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-09-28 06:15 PM
Thanks for the reply.
Yes, it's a basic Archicad window.
In that dialog box, I can control how far the window sill overhangs left and right (parallel to the wall), but I don't see where I can control its projecting depth perpendicular to the wall.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-09-28 06:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-09-28 06:51 PM
Are you able to set it to 0? Actually, mine won't go less than 3/4" but I don't understand what's controlling that, either.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-09-28 07:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-09-29 01:48 PM
Changing that wall closure to custom helped get me close enough, it's not past but it's not sticking out as far.
Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2020-09-29 01:58 PM
In alternative, you could create an empty opening and fill it with another transparent wall with a proper width. Then insert your window in this transparent wall. This way you'd have total control of your window width without changing the wall.
