How do you control the MUL command?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-03-07 04:19 PM
2008-03-07
04:19 PM
Besides just throwing in random numbers till I get something close is there a way to make my object show up at the correct scale? The rest of my project is at 1/8th scale.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-03-07 06:30 PM
2008-03-07
06:30 PM
Hi Seraphim,
Just curious, what do you mean 'The rest of my project is at 1/8th scale.'? The displayed scale shouldn't have any effect on a library part unless you have coded in some sort of scale sensitivity.
You haven't actually modelled the building at a scale have you?
Try posting up some of the code, and someone may be able to spot what the problem is if you're still having problems.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-03-07 07:14 PM
2008-03-07
07:14 PM
Here is my current 3D Script:
MUL 0.025, 0.025, 0.025
FPRISM_ plastic_material, plastic_material, plastic_material, plastic_material,
5, 0.125, 45, 0.125,
0, 0, 15,
2.5, 0, 15,
2.5, 4.5, 15,
0, 4.5, 15,
0, 0, -1
DEL 1
I think the question I'm really trying to ask is what are the values used in the MUL command measured in?
As far as "the rest of my project is at 1/8th scale", I agree that was poorly phrased. I mean all of my output is to 1/8th scale. I recently switched from 1/4 scale and I've had to convert a lot of text.
0, 0, 15,
2.5, 0, 15,
2.5, 4.5, 15,
0, 4.5, 15,
0, 0, -1
DEL 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-03-07 08:13 PM
2008-03-07
08:13 PM
Looking at your script, it looks like you can just eliminate the MUL transformation and add inch marks (") after your values to clarify your unit of measure.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-03-07 08:34 PM
2008-03-07
08:34 PM
Following on from Laura, I believe from my limited GDL knowledge, GDL works in metric unless you tell it otherwise.
Your Prism was actually 2.5 metres by 4.5 metres (approx 8ft by 14ft)
The MUL command literally multiplies (scales) by the number i.e. MULx 2 multiplies everything by 2 or twice the size, MULx 0.5 halves the size. MULx 1.0 should do nothing!
Hope that's helpful!
