alexliz24
Eye-dropper transfer of params seems to not transfer them
I've got these two project files. Both use the same libraries. I pick the parameters of one window in project 1 with the eye-dropper, then switch to the other ArchiCAD running project 2 and Opt-Cmd click the window to make it identical to the one from project 1. Nothing changes.
Is it to do with the GUID philosophy? Do I need to keep something in mind? I'm really stumped and the problem is I face this kind of need (i.e. to transfer params between project files) a lot!!!
Thanks, people.
Alex Zachopoulos
MacBook Pro 17" 2.4GHz, MacOS X 10.5.6, ArchiCAD 11 & 12, WinXP, Vista (well, not really Vista...)
TomWaltz
sorry, but Transfer Parameters only works within the same file/instance of Archicad.
The closest you could probably get would be to copy/paste an element from one session to another, then match it.
Tom Waltz
alexliz24
Many thanks, Tom! I did a copy/paste of the wall containing the window, then param-transferred (is that a word?...) and it worked.
However, I still have a project with two doors, one on story 1 and one on story 2, and parameter transfer doesn't work. The clicks all take place, but door 2 doesn't end up identical to door 1.
Comment, anyone?
Alex Zachopoulos
