How to control the Furniture door fill in elevation
How to control the fill on furniture door in elevation view. I use object - Kitchen Cabinets 24. The fill on doors appears turned at 90°. How can I control fill direction?
1 Solution
It seems the cabinet is using the material rotated from its intended direction.
I am not familiar with that object so do not know if there is an option to rotate the material or maybe it is a custom door panel.
If you can't control it in the object, then you could duplicate that material and rotate the fill.
Then use the duplicate material in the cabinet.
Go to post
3 Replies 3
I have been test this situation on different object. The situation on different object is different. Then is necessary to have two the same fill rotated at 90°.
vdentello
The quickest solution would be so.
But seems like there´s an inconsistency in Texture mapping, hope they'll fix that. They shouldn't be rotated.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
