Hi All I am a rookie for Archicad.
I would like to create door (Door hinge 4sashes) as sketch I had attached.
For now i create Door leaf and change in Door family. In 3d view is look ok. But elevation and plan is show not correct because i use door family base on single swing and i change door leaf by custom.
Anyone can suggest how to change 2D plan and elevation symbolic follow 3D as i want.
Thank you so much
.![0FFCFDA8-A607-44E1-97C1-D0334CA8B5BC.jpg 0FFCFDA8-A607-44E1-97C1-D0334CA8B5BC.jpg](/t5/image/serverpage/image-id/76213iF2A010A7D0E2C538/image-dimensions/484x447?v=v2)
