2003-11-13 04:13 PM
2006-08-12 02:31 AM
Peter wrote:Oh sorry, That is a mistake! You know, lazy people like me like to copy & paste........
LiHigh,
the code takes the slab elevation
and adds the height of the the current wall tool
wall height setting (WALL_HEIGHT).
Why did you do this ?
2006-08-12 02:58 AM
2006-08-15 10:41 PM
2008-11-09 12:43 AM
2008-11-11 07:29 PM
2008-11-16 11:17 AM
James wrote:James
Trying attachment again...
2008-11-17 08:06 PM
Krippahl wrote:Thanks Miguel, of course it's fine for you to link to it.
why it is not at the GDL Object Depository.
2009-01-24 12:30 AM
Matthew wrote:Hi Mathews,
Wolf,
You are right that you need to make your own level dimension markers with the object tool. The good news is that you can make them better than the Level Dimensioning tool does. I made one that changes its appearance according to whether it is used in plan or section. It automatically picks up the elevation above project zero in section and it displays the z-height in plan (allowing auto slab, roof and mesh spot elevations using the gravity feature). The only limitation is that they can't be linked to other model elements so they have to be manually updated when things change.
If you like (and any others of course) I can e-mail you the part to adapt to your own needs.
