How to make 5 part bay window?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2018-03-01
06:21 PM
‎2023-05-26
02:14 PM
Rubia Torres
‎2018-03-01
06:21 PM
Please check below image, i am trying to model below bay window . Library bay windows are not good for this task, so looking for some alternative to draw the 5 part bay window. Please advice.
Actual house picture is also attached for which I am trying to model the 5 part bay window.
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-02 02:24 AM
‎2018-03-02
02:24 AM
If the standard bay window object is no good then you will need 5 walls with one window in each.
Stretch to the required width and adjust the corner settings to suit the angles.
I don't use the standard GS windows but I know they have corner options.
Hopefully if you use different windows they will all connect the same.
Otherwise create your own corner posts with the column tool.
You may also need to use empty openings to cut the wall away at the columns.
Then place windows in between the columns.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-02
02:24 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-02 03:32 AM
‎2018-03-02
03:32 AM
You can set custom corners on single windows to get continuous corner frame at the angle of your wrap.
Window Settings => Custom Corner
The issue with your window is the central window. I don't think there's a default window that has a two pane transom over a single large pane...
Ling.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-02 12:24 PM
‎2018-03-02
12:24 PM
Thank you for good suggestions. They worked very well in this case.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-03-06 03:06 AM
‎2018-03-06
03:06 AM
How did you do the two top hung windows in your central transom? Or have you just done them as a sash with a horizontal division?
Ling.
Ling.
