rob2218
How to make a SKP file imported into AC look simpler in 2D?
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
6 Replies 6
Search and you will find:
http://helpcenter.graphisoft.com/tips/removing-triangulation-from-imported-sketchup-cinema-4d-and-3d...
rob2218
you D-Man!
and don't let neither Lasz nor Nick tell you otherwise...
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ok...well, gave it a shot.
it's a bit....not quite like I had hoped...but will continue to search.
thanks Karl.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
getting a little better....getting some weird "polygon degenerated" feedback but...oh well.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erich
The chair appears to be a symmetrical morph. Cut it in half then mirror a copy and union the two halves back together.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
David Maudlin
Rob:
For another approach to editing the 2D Symbol of an Object see: 2D symbol of Archibase.net objects.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
