‎2025-05-20 09:24 AM
I have seen that in previous versions of Archicad (22 e.g) , there was the option to make the opening lines of windows and doors as dashed or full. I cannot find this option anymore (I am using Archicad 25 at the moment). Is this still possible to do? Are there any other ways of doing this that don't involve drawing the lines by hand on top of each opening?
Thank you very much
Solved! Go to Solution.
‎2025-05-20 09:49 AM
I don't have 25 running at the moment, but in 28 you can control it in the Model View Options.
I am assuming it is similar in 25.
‎2025-05-20 09:54 AM
Thank you Barry, it worked!
