How to put Input over Image in User Interface GDL
Hello, I have an image in the user interface and I want to put some Inputs over the image.
I managed to position them where I want, only that it doesn't work, only those that are out of the picture work.
Is there any possibility to order them on the Z axis, for example Z +1, the image to be down and the inputs to be over to work?
I have
UI_PICT 'arch.png', 0, 0, 370, 320
UI_INFIELD "l_fund", 100,100, 60, 20
6 Replies 6
runxel
You're on the right track: Things that come later in the script are getting drawn above the items which came before.
But – and I admit this is really silly and inexplicable – to be able to write into that infield, you have to put it there twice: once before and once after the ui_pict.
¯\_(ツ)_/¯
I.e.:
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Lingwisyer
Guru
Is that not what DRAWINDEX is for? I have never used it, but by the reference guide that is what is does.
Yes this can be a bit of a problem but runxel has given you the solution.
The UI_INFIELD scripted before the UI_PICT is the active one that the user can alter.
But the problem is that the UI_PICT covers it and the user can't see it.
So you add a second UI_INFIELD after the UI_PICT that the user can see (but isn't really the one they are altering).
For some reason that I can't understand, just having the UI_INFIELD after the UI_PICT as you have done, while visible to the user, it is not editable.
I haven't tried with images that have a transparent alpha channel, so I am no sure if that makes any difference.
No that is for layering the 2D images displayed by the object.
This problem is in the user interface.
Lingwisyer
Guru
Ah. I had figured that I would work with the UI Script as well as it is essentially 2D as well.
Thank you very much! Good luck with the forum, there are no video tutorials.
