2017-06-1501:25 PM - last edited on 2023-05-2412:28 PM by Rubia Torres
2017-06-1501:25 PM
I wonder is there a way to remove this thick line between door and window? The objects are separate, because I can't create door with triple window using one library object. This line bugs me off as I have this all over my project and the only solution I know is to use 2d drafting and mask the issue, but it's not ideal. Also I don't want to change wall pen.
