2011-08-09
06:53 PM
2023-05-24
10:53 AM
Rubia Torres
2011-08-09 08:35 PM
2011-08-09 08:57 PM
2011-08-09 09:52 PM
2011-08-09 10:56 PM
2011-08-10 08:34 PM
Durval wrote:In this case, the parameter is replacing the Contours pop up in AC 7 (see image below), so it moves from the dialog box, where it cannot be scripted, to the GDL arena. In your case, the object will not accept user input to change the parameter, which is more of a bug.
I thought the blue parameters, created by default when setting subtypes, would not have any effect on the object unless they were used in the scripts. It seems that I was wrong...
Durval wrote:It is not the fact that it is not used in the script, it is an additional parameter that could be controled by a script(s). The next parameter Hotspots 0-None,1-2D,2-3D,3-All has a similar function: to automatically add (or not) the 2D and 3D HotSpots, so the HotSpots can be scripted, or added without scripting.
Is there any other blue parameter that do affect the object even if not used in the scripts?
