How to store values for later use?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-06-19 06:34 AM
‎2015-06-19
06:34 AM
My situation can be simplified to something like this. I'd like to store the values "A" and then turn it into previousA. And then store the values of "A" again when user change it, and turn it into currentA. So I can do something like:
differentA = previousA - currentA
Is there a way to do this?
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-19 07:46 AM
‎2015-06-19
07:46 AM
Create parameters for ‘previous_A’ and 'difference_A'
Create a boolean parameter called ‘set_previous’
You don’t need a parameter for ‘current_A’ because that is ‘A’
if set_previous = 0 then
previous_A = A
PARAMETERS previous_A = previous_A
set_previous = 1
PARAMETERS set_previous = set_previous
endif
difference_A = previous_A - A
PARAMETERS difference_A = difference_A
This will constantly give you the difference based on the original ‘previous_A’.
Now you can set a new value for ‘A’ and turn off the ‘set-previous’ switch and it will reset the ‘previous_A’ value and the switch will instantly turn back on again.
Type in a new value for A and you will have a new difference.
Not quite sure what you would want this for but it will work.
previous_A = A
set_previous = 1
endif
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-19 08:09 AM
‎2015-06-19
08:09 AM
Thank you so much for your quick reply, Barry. I'll test/apply your idea asap.
