I need help making my object "smart"
I created a frame to place around windows with a molding made from a complex profile, but once I save it as an object and place my object in the plan, if I give a measurement, it's original measurements of the molding changes and distorts, I know now that I have to make the object "smart" but It's confusing and I don't know how to do this,
Can anybody help me with this please?
Thanks!
7 Replies 7
Dwight
I can't make the url work
search Google for "Introduction to object making with Archicad"
there's a downloadable PDF.
Dwight Atkinson
vfrontiers
I would suggest that if you want an editable object you use PROFILER (the add-on) instead of complex profiles. Complex profiles add way too much senseless code to the resulting part...
In PROFILER, you have the same profile and will have a SQUARE (polyline) as the PATH. Once you open up the .gsm, you will be able to identify which number relate to the path and which relate to the profile. (use the gdl reference pdf in the help menu of AC for more info)
Simply replace the path nodes with VARIABLES. Most likely you will want the PATH to match the window opening.... so you identify the INSIDE of your profile as the point of extrusion. Then when you type in A & B on your part, they can match the window opening size.
Profiler will builld the object laying down, so you'll also have to include a rotx 90 at the beginning.
It is really easy to do (but seemingly hard to explain).... If you make a module of the PROFILE as a fill (copy the one out of your complex profile) and email it to me, I can whip up...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Hi Duane,
I downloaded the PROFILER add-on, I created the molding, but I'm stuck, I'm new in object creation, I apreciatte all your help.
I need to use my frame exactly as you explained it to me, I need to place this frame around diferent sizes of windows and I need to give the inside measurements of the frame (the size of the window).
I will really apreciate your help,
Thanks,
what email address do you have to send you the module of the profile?, I hope I understood well,
Thanks again!
Thank you also Dwight.
Mario Igartua
vfrontiers
Check and see if it's an extra install on the DVD... I can't locate it GOODIES at the website.... I'd send you mine, but it's MAC version.
Duane
Visual Frontiers
AC3.14 - AC29
I looked for the old Profiler also.
Kinda says there is a link there, but when it takes
you to downloads, no link is found.
Anybody with a windows version?
It could be sent to lllbier@gmail.com
if you don't want to post it here.
Or any other info on how to get it would be great.
Since it is no longer on web, I'm sure it would be
a huge waste of time to bug G.S.
Thanks
Bier
ps.
I took a look at dvd and did a "explore" of the 12 dvd, but did not find
any goodies on it.
Did I miss something?
For some bizarre reason, Profiler is not listed on the USA Goodies page, but it is listed on the international page.
The international download should work fine with a US installation:
http://www.graphisoft.com/support/archicad/downloads/goodies12/INT.html
Thanks Karl
Got it.
Works great.
Bier
p.s.
Thanks Duane
for posting the concept.
